Apr 13, 2007, 8:03 AM
Post #3 of 4
(1214 views)
Re: [mathias79] Philips 27PT54 3S37A
Most modern TVs work on a sytem knpwn as I squared C or IsqC or various variations of that. It is a system where a bus line goes through each stage then back to the processor, if a stage fails the bus stops. A new bus powers up and drive the road, it falls into the ditch and the system stop for that moment. The processor now sends another bus, another failure, another hesitation. So what is wrong with your set, you need to drive the road and find the pothole, That is not an easy task, I wish you luck.
