Philips 50P8341
boriquafl1
Jan 19, 2010, 2:10 PM
Post #1 of 4 (2001 views)
Philips 50P8341 Can't Post
Hi all, I have a philips 50p8341 PTV915, I just noticed that the tv shuts off by it self. It started recently I'm watching tv and next thing you know you cant use the remote for nothing at all, after that it shows a display saying that the tv will shut off in about XX seconds, after it shuts off nothing at all, I cant turn it on on the set or by the remote, I noticed that if I unplug it and plug it back in it will come on. I recently did a CRT coolant change and cleaned as much dust as I could, I ensured that all connections where tight and plugged in, after that it had a bad alignment, so after doing some reading I adjusted thru the service menu hitting 062597 code, I when ahead and did a manufacture reset, can I have thrown something out of wack thanks
boriquafl1
Jan 20, 2010, 12:31 AM
Post #2 of 4 (1992 views)
Re: [boriquafl1] Philips 50P8341 [In reply to] Can't Post
OK update, the tv shows codes 7, 17, 30 any ideas what i need to look at
Error code table
Code Number Error Description
00 Not an Error
01 Too high I-beam or East/West protection
02 Vertical protection
03 X-Ray protection
04 5 volt protection
05 - not used
06 General IIC error
07 BC loop not stabilized
08 Bocma TDA888X IIC error
09 Bocma IC 8v failure
10 NVM IIC communication error
11 Wrong NVM type
12 Microp internal RAM error
13 Main tuner IIC failure
14 Sound IC failure
15 SRAM test failure
16 PIP Tuner IIC failure
17 ECO Pip IC or DW Pip IC failure
18 I/O expander I2C error
19 Gemstar Guide Plus board
20 V-chip located on the DW Pip
21 Non-Volatile clock
22 Incredible picture (YUV) CR
23 Bocma DoubleWindow TDA888X error
24 - not used
25 - not used
26 - not used
27 Virtual Dolby
28 - not used
29 - not used
30 CSP i2c error
31 CSP NVM i2c error
32 CSP NVM error - not valid data
33 CSP dac i2c error
FUXER
Jan 20, 2010, 8:12 AM
Post #3 of 4 (1987 views)
My guess is you have disturbed something- 1st try removing cell/batt from remote- to see if remote has locked key- next repeat everything you did re alignment,remaking joints etc- esp look for bent pin /contact. After this, you have the code info -just check as listed.
Jan 20, 2010, 10:42 AM
Post #4 of 4 (1986 views)
And your "day job" is?Smile
