Mar 27, 2005, 10:45 PM
(1684 views)
Re: [dhoyland] Philips TR2503 C221
I do not have a schematic for that specific model, however, I suspesct that this is one of the chassis that have a high failure rate on the vertical output IC which causes the set to shut down. This failure is usually accompanied by the failure of the + and - 13 volt B+ diodes and there associated fusuble resistors. You might want to check out www.FreeFlatScreens.com/?r=10948674 for an opportunity to earn a free replacement for this set with a little effort on your part.
