Phillips 28" TV
bruno68
May 9, 2005, 3:03 PM
Post #1 of 4 (4808 views)
Phillips 28" TV Can't Post
Hi,
My Phillips TV is connected to a Sky + Box via the AV. When you switch the set on the lights go from red - Orange - Green and all is OK
Lately when the set is turned on, the Red light flashes continuously.
I have found that if you keep switching the box off and On, then 1 in 20 times the red light stops flashing (After about 10 minutes). At this point 1 in 3 times is you change the channel the lights go green and normal TV is resumed.
shadetree
May 9, 2005, 9:59 PM
Post #2 of 4 (4795 views)
Re: [bruno68] Phillips 28" TV [In reply to] Can't Post
shadetree
May 9, 2005, 10:00 PM
Post #3 of 4 (4794 views)
if this is on the box it means you have a message
bruno68
May 10, 2005, 2:37 PM
Post #4 of 4 (4786 views)
Re: [shadetree] Phillips 28" TV [In reply to] Can't Post
Sorry perhaps my description was not good. The TV Flashes a red light and doesn't work anymore. There is no message facility on the TV.
The only reason I enquired on this forum was because by repetitavley switching off/on the TV, you sometimes get the TV set working. This points to a fault that may be possible to overcome without vast expense.
Regards,
