Pioneer SDP5065 problems...?
markedman450
May 17, 2005, 5:22 AM
Post #1 of 4 (1545 views)
Pioneer SDP5065 problems...? Can't Post
I recently got a 1993 Pioneer SDP 5065 projection tv. Powers on fine..but right now the coax input for cable doesnt work...the picture is not all snowy but very hard to see, and the sound does work. As for the RCAs, they are the same way at first when you first turn the tv on, but after 5 minutes the picture will come up fine, colors look good and all. I do notice when watching a movie using the RCAs that when bright colors come up like yellow, the picture starts flashing and cutting out a little. I was told by a friend who knows a decent amount about projections to replace all the fuses and resistors and capacitors and to clean the guts out too? Any other suggestions would be helpful or if anyone happens to have a diagram of the guts of this tv that would be awesome.
(This post was edited by markedman450 on May 17, 2005, 5:29 AM)
markedman450
May 19, 2005, 3:23 AM
Post #2 of 4 (1532 views)
Re: [markedman450] Pioneer SDP5065 problems...? [In reply to] Can't Post
Called a tv repair place, they too said it prob is the capacitors. Any help or advice be appreciated. Also if anyone has a diagram of my tvs guts that would be awesome so i know where to locate these capacitors.
minehunter
May 20, 2005, 1:52 PM
Post #3 of 4 (1525 views)
I think your problem is the tuner. The way to check is to use the remote and put the set on video input and have a VCR connected there.If you get a picture then the problem is your tuner. The only fix is to replace it or you can use the video input and the tuner on the VCR to change channels. Not channel three
markedman450
May 20, 2005, 8:58 PM
Post #4 of 4 (1517 views)
Im not as much worried about the coaxial input not working as the picture itself flickering especially when the colors are yellow on the screen. When you first turn the set on it takes 5 minutes for the picture to show on the video inputs, the coaxial doesnt work at all.
