Proscan PS32800
swelect
Oct 17, 2005, 9:43 PM
Post #1 of 3 (1563 views)
Proscan PS32800 Can't Post
Have a Ps32800 with no audio. Chassis MM101. problem appears to around U11800. Audio comes in but no output. Changed Ic. No difference. Any assistance would be appreciated.
Wiz
Oct 17, 2005, 10:59 PM
Post #2 of 3 (1559 views)
Re: [swelect] Proscan PS32800 [In reply to] Can't Post
When you say that it is getting audio in, I presume that you mean that the chip itself has input on the input pins, but no output on the output pins. If this is the case, check that the IC is getting its correct voltages.
Also, although it is unlikely, the new IC could also be faulty since manufacture. If this is the case, you are exteremly unlucky.
swelect
Oct 18, 2005, 1:44 PM
Post #3 of 3 (1554 views)
Re: [Wiz] Proscan PS32800 [In reply to] Can't Post
HI
If I jump the in on pins 17 and13 to the output pins 26,27 I get audio at a medium level with no volume control. The chip is a TDA7312. The chip appears to work but may have a system control or eeprom problem. I have no schematic just block diagrams.
