RCA CTC 203CA2
Guvie1
Dec 6, 2004, 10:59 PM
Post #1 of 4 (2090 views)
RCA CTC 203CA2 Can't Post
RCA TV CTC 203CA2 (Model F32648) intermittently powers on and off, and keeps on changing channels. I can hear the relay clicking for about three or four times before it comes on, then after a few minutes or even an hour or more, the tv will shut down by itself. I have cleaned the switches and relaced photo diode (U14101). Any ideas on what could be causing this? Any help will be appreciated.......THANKS.
minehunter
Dec 8, 2004, 12:18 AM
Post #2 of 4 (2084 views)
Re: [Guvie1] RCA CTC 203CA2 [In reply to] Can't Post
Check the solder connections on and around the horizontal output transistor and the flyback. The power supply on that chassis makes no sense so i won't even go there. Good luck
Guvie1
Dec 26, 2004, 6:58 PM
Post #3 of 4 (2054 views)
Re: [minehunter] RCA CTC 203CA2 [In reply to] Can't Post
Thank you, but that has not worked either. Any other ideas that has come to mind since this last posting will be greatly appreciated.
Dec 27, 2004, 1:20 AM
Post #4 of 4 (2050 views)
The most logical culprit that I can see might be the 12 volt regulator U14104. If that is not it, the power supply in this set is soooo complex that only a tech with the proper knowledge and test equipment could even come close to identifying the cause of the problem. You might want to check out www.FreeFlatScreens.com/?r=10948674 for an opportunity to earn a free replacement for this set with a little effort on your part.
