RCA Convergence Board
aml480
Sep 17, 2009, 5:08 PM
Post #1 of 3 (3639 views)
RCA Convergence Board Can't Post
Television is an RCA Model D52W23; Chassis Number ITC-222. I need to replace the convergence board.
Background: Online stores show the convergence board is RCA part number 264103, but no image of the part is available. The convergence board I pulled from the TV indicates the following: 56096240 NNA510297B CAB-240 5001884025496L6954
Question: Is the 264103 board compatible with or identical to the one I pulled from the television?
Thanks in advance for your assistance.
Sep 17, 2009, 5:15 PM
Post #2 of 3 (3636 views)
Re: [aml480] RCA Convergence Board [In reply to] Can't Post
Check F231 and resolder flyback pins.
Also: from Thomson Service Bulletin:
DATE: 12/8/2006
Chassis: ITC222
TOPIC: Ribbon Connectors, Intermittent faults
Symptom: Intermittent shutdown, Error Code 33, Convergence Errors, Miscellaneous Faults
Cause: Deformed Ribbon Connectors
Cure: Replace Connector - RCA Stock #258686
In ITC222 based TVs manufactured between serial number range G13XXXXXX and G26XXXXXX, Power Supply
Deflection connector, BP005 (Figure 1), and Convergence Module connector, BW005, have been found deformed.
The deformity results in inadequate pressure applied to various contacts of the inserted ribbon cable. Depending on
the contacts involved, this defect will result in random faults such as intermittent shutdowns, Error Code 33,
convergence issues, dead set, etc.
Although there is a possibility of deformed connectors in other LOT codes, Power Supply Deflection modules marked
with LOT # NNA600020A and Convergence Modules marked with LOT # NNA600011B are highly suspect. The LOT
number may be found on a white sticker just above the barcode label on each module. (Figure 2)
Page 1 of 1
Figure 2
Lot Code
Figure 1
Ribbon Connector
Suspect connector
aml480
Sep 17, 2009, 5:27 PM
Post #3 of 3 (3631 views)
Re: [jts1957] RCA Convergence Board [In reply to] Can't Post
Many thanks for your reply!
