probuilt
Oct 13, 2005, 12:53 AM
Post #2 of 5
(1901 views)
Re: [MC] RCA PROJECTION PROBLEM
If you do a search for "convergence STK's" you will find many descriptions of different problems, but they all come back to two things. Either the solder joints of the STK ic's are cracked, or the STK ic itself has pooped. If you feel up to the challenge, the parts can be ordered on line very reasonably. It's still no guarantee that it will fix your problem. For that you should call a local repair tech for a in-home estimate to rule out anything else. Also, even though most people here will tell you that this is definitely the problem, there could be other minor issues to accompany the STK's. i.e. capacitors, resistors, micro fuses, or filters. It's not always a straight forward fix, but if you're capable of using a soldering iron, it's worth the money to try. Aslo, you might be interested in earnig a new tv for free Copy and paste this on your browser to get a Flat Screen for free http://flatscreens.freepay.com/?r=23486733 Just ask "Mel" he did it too. Learn from the Pro's
