Visiting Tech
Jan 3, 2006, 11:25 PM
Post #2 of 9
(2700 views)
Low high voltage ( 2nd anode ) to the picture tube can cause this. B+ power supply or flyback transformer. There is also a hidden service menu in which you can shrink the horizontal and vertical size. Run a search here on your chassis model for the how to, It is usually done with holding front panel buttons while pressing the power button, The menu pops up and you enter a password number. You will need the codes to know which adjustment setting you are on.
