RCA R52WH74
YAMARACER
Jan 11, 2010, 11:33 PM
Post #1 of 2 (1177 views)
RCA R52WH74 Can't Post
I am no tv repair man but I can solder and use a multimeter, anyway I had a guy tell me that my convergence problem was the fuse on the power/deflection board in the middle and I think he called it a flyway.
I replaced the entire board with a new board and had the same problem, I then took the old board and installed a new fuse and resoldered all the points on the flyway. Installed the now repaired old board back in the tv and tried again. still have a convergence problem.
I pulled the board again and rechecked the fuse and found the fuse was good. It is not adjustable through the service menu.
Anybody have any clue what I might look for or should I just trash this unit and go buy new.
Thanks in advance guys
Jan 12, 2010, 2:37 AM
Post #2 of 2 (1174 views)
Re: [YAMARACER] RCA R52WH74 [In reply to] Can't Post
Sounds like if you keep going the way you've been going, you're going to spend even more money and probably still have a set that doesn't work.Smile
1) Flyback, NOT flyway.
2) New, "TO YOU" anyway, board or a genuine "NEW" board?
3) Ribbon cable/connectors bulged?
4) "SERVICE" menu is the LAST place YOU should be. Perhaps you meant CUSTOMER menu?
