RCA model# M50WH72S
BigScreenLover
Nov 4, 2013, 8:36 AM
Post #1 of 6 (1366 views)
RCA model# M50WH72S Can't Post
Picture will turn on then after 23 seconds will shut off, the power light will then flash 5 times and stay on then the picture will come on and it repeats this (sounds is still there) Why??? I know that the flashing light means something significant but what???
Nov 4, 2013, 10:09 AM
Post #2 of 6 (1361 views)
Re: [BigScreenLover] RCA model# M50WH72S [In reply to] Can't Post
Check CP624, CP639, CP641 & CP647
BigScreenLover
Nov 4, 2013, 10:22 PM
Post #3 of 6 (1345 views)
Re: [jts1957] RCA model# M50WH72S [In reply to] Can't Post
I've googled those terms and am getting no where....is there any more info you could tell me to fix the problem...thank you
BigScreenLover
Nov 4, 2013, 10:41 PM
Post #4 of 6 (1343 views)
Kind of sounds like the fan isn't working too...is that possible? Is it an easy fix if that is the problem? Is it pricey? Is it worth fixing???
Nov 4, 2013, 11:19 PM
Post #5 of 6 (1340 views)
Searching 'CP624' in Search Posts above or Googlin' 'RCA CP624' produces desired results.Wink
(This post was edited by jts1957 on Nov 4, 2013, 11:19 PM)
BigScreenLover
Nov 7, 2013, 6:14 AM
Post #6 of 6 (1322 views)
ok...thanks, just seen.....so I should change the lamp to fix the problem????
