Sumo Runner
Jan 8, 2011, 4:01 PM
Post #1 of 4
(6034 views)
RCA white screen
I have an RCA L26HD31 where the picture went bad. It's out of warranty of course. Sound is OK, channel changing is OK, even screen menu selections work. There is just a slight image if you look closely but it is mostly white and very dim. I opened the back and there are no bulging capacitors and no burns or obvious bad wires or solders, so I don't suspect the power board. I'm left with replacing either the main board or t-con. Which one is more likely to be bad? If it's the main board or the lcd panel it's a throw away but I can get a t-con for about $50.
