FLL41
Jun 10, 2007, 7:04 PM
Post #1 of 6
(2987 views)
Replacement Posistor
A near-by lightning strike blew the mains fuse on my Sanyo 23 inch CRT TV (model DS24425). Resistance tested okay at the fuse holder, so I replaced the fuse and it blew again. I removed the positor at PS601 on the circuit board and the TV now powers up. The color is funny. But otherwise it is working. But, I'm having trouble locating a replacement posistor. It is a 3 ohm made by Murata. I found a 3 ohm, 125 volt Murata posistor online. But, I don't know if it is the same one that was in the TV. Do you think it will work and is it likely to solve the color problem? Also, I unplugged the degausse coil to test the resistance at the fuse holder. Does it matter which way it plugs back in (is there a polarity on the coil?). Thanks for the help.
(This post was edited by FLL41 on Jun 10, 2007, 7:06 PM)
