Right track????????
electron00
Aug 10, 2005, 4:01 PM
Post #1 of 2 (1300 views)
Right track???????? Can't Post
Toshiba model TP55G60, chassis TAC9753 (12/97):
Would not start up. I could here relay click and high voltage come up/back down with LED flashing on/off:
I pulled the harness going from convergence amp to red gun. Power stays on with picture but of course red convergence is bad.
Measured -14v on pin 18 of red amp. 0v on pin 18 of blue amp. Can't switch harnesses to check.
Is it red amp or red gun (convergence yoke)?? Thanks
Larry E
Aug 12, 2005, 9:28 PM
Post #2 of 2 (1278 views)
Re: [electron00] Right track???????? [In reply to] Can't Post
Hi, Are you sure you measured voltage on pin 18 ? Should be negative
15.9 on pin 17 of both STK`s, Zero volts on pin 18, if you verify that
you have -14 on pin 18 I would ohm out pin 17 to 18 to see if those
2 pins are shorted on that IC, hope this helps, Larry E
