SONY 32KVRX
denylson2002
Nov 17, 2009, 7:39 PM
Post #1 of 6 (886 views)
SONY 32KVRX Can't Post
I HAVE A TRINITRON SONY TV 32KVRX, WHEN IT IS TURNED ON , IT SOUNDS OK, BUT THE PICTURE LASTS ABOUT 6 MINUTES TO SHOW, IT LAST 5 MINUTES ON AND THEN IT IS OFF AGAIN , AND THEN TURNS ON OK JUST BY ITSELF. AND IT KEEPS TURNED ON OK AFTER THAT. THIS HAPPENS ONLY WITH THE PICTURE, THE SOUND IS OK.
I WOULD APPRECIATE ANY HELP.
Nov 18, 2009, 2:37 AM
Post #2 of 6 (881 views)
Re: [denylson2002] SONY 32KVRX [In reply to] Can't Post
If Timer LED flashes while picture is GONE ... Weak CRT. Sneak G2 (Screen) up a tad or rejuve picture tube.Wink
denylson2002
Nov 18, 2009, 4:12 PM
Post #3 of 6 (878 views)
Re: [jts1957] SONY 32KVRX [In reply to] Can't Post
yes, the timer led flashes when the picture is gone , but could you tell me how should i rejuve the picture tube ? I am a rocky in this matter.
Nov 19, 2009, 1:55 AM
Post #4 of 6 (871 views)
With a picture tube tester/rejuvenator.Wink
Every well equipped TV repair shop should have at least one.
denylson2002
Nov 20, 2009, 3:20 PM
Post #5 of 6 (856 views)
THANKS FOR YOUR HELP ,JTS1957.
I THINK IŽLL HAVE TO BUY A PICTURE TUBE TESTER, ACTUALLY, I DONŽT HAVE A TV REPAIR SHOP, I AM DOING THIS JUST AS A HOBBY AT HOME. IF THERE IS ANOTHER WAY TO DO THIS (REJUVE THE TUBE) , PLEASE LET ME KNOW. THANKS A LOT.
Nov 23, 2009, 9:48 PM
Post #6 of 6 (838 views)
I have never had much luck in trying to rejuvinate a trinitron tube so you could be wasteing your money buying a CRT tester (which are not cheap). If turning up the screen voltage does not work, you can increase the heater voltage by isolating the filament pins on the CRT board, wrap three turns of insulated wire around the flyback core and attatch the ends to the filament pins on the CRT board. This will be a temp fix but it might give you one or two more years of life on the CRT.
