SONY KV32ST36
edc3000
Dec 20, 2004, 2:56 AM
Post #1 of 8 (1921 views)
SONY KV32ST36 Can't Post
No power , no picture no sound, fuse is Ok.
Any idea? Who can help?
Joe
Dec 21, 2004, 1:20 AM
Post #2 of 8 (1905 views)
Re: [edc3000] SONY KV32ST36 [In reply to] Can't Post
Is the standby light blinking or is the set completely dead?
edc3000
Dec 21, 2004, 1:21 AM
Post #3 of 8 (1904 views)
Re: [mel] SONY KV32ST36 [In reply to] Can't Post
It is dead , no light, Any Clue?
Dec 21, 2004, 3:05 AM
Post #4 of 8 (1891 views)
No blinks at all indicates a problem in the standby power section which is quite complex and could involve a failure from a fusible resistor to a transistor or a power module. Only a qualified tech with the proper test equipment can say for sure thru hands on troubleshooting. Incidentally, I believe that the model number should be KV-32TS36 since I do not show an "ST" number in my files. You might want to check out www.FreeFlatScreens.com/?r=10948674 for an opportunity to earn a free replacement for this set with a little effort on your part.
edc3000
Dec 21, 2004, 3:30 AM
Post #5 of 8 (1891 views)
Thanks, Mel any idea guys what is the cost of repair for this problem?
Dec 22, 2004, 2:05 AM
Post #6 of 8 (1875 views)
Without knowing which and/or how many parts need to be replaced an estimate would be difficult. Around here, you are looking at at least $65 for a bench check. Being pessimestic, I wouldn't count on it being less the in the $100 to $150 range if that low
edc3000
Dec 25, 2004, 4:41 AM
Post #7 of 8 (1856 views)
The PS was fixed ,But after 5 min only black and white pickture any idea how to fix it?
Dec 26, 2004, 12:12 AM
Post #8 of 8 (1849 views)
My troubleshooting notes require the use of an oscilloscope, but I have found that this problem usually involves the 3.58MHZ crystal or the jungle IC.
