fobobobo
Jan 6, 2007, 12:58 AM
(1655 views)
SONY Trinitron (KV-27V55)
Hi all! I need a wee bit of help here. A neighbor's sony died. It would not power on (she bought a brand spankin’ new 40" bravia lcd). So, I decided to take the old set and work on it. It did not power on, so I suspected that it was a power supply issue. I opened it up and found that R607 was bad, so I ordered a kit from electronix.com that included that fusible resistor, Q601 + Q602 (transistor part # C4834), and the horizontal out transistor (C4927). I also checked D625 (the diode close to R607). I replaced R607, but decided to take the chance on leaving the other components as is. I did not resolder the transformers or any other components as other forums suggested. Then I reconnected everything, plugged the tv into the outlet, and BOOM! Caps 609 and 611 exploded instantly (yes there was enough smoke to get a wiff of). So, here I am, wondering what went wrong, along with trying to find replacement 224nf caps, at which I have been unsuccessful. Any ideas on what went wrong, and where to get the same value caps? Also, can someone tell me the biased/reverse biased resistance on D625 if they are working on the same set, because my readings were weird? Thanks! One of the other forums I checked out was <a href=” http://www.anatekcorp.com/faq/archtv-1.htm</”>http://www.anatekcorp.com/faq/archtv-1.htm</a> , the last post on that was in 2004
(This post was edited by fobobobo on Jan 6, 2007, 12:58 AM)
