bcarroll_us
Jul 24, 2016, 5:01 PM
Post #3 of 8
(1913 views)
Re: [jts1957] Samsung 40" mystery
Hi, thanks for the suggestion. I just started taking these measurements by unplugging the ribbon from the main board (so the cable is still plugged into the power supply), but realized once I got to the measurement after one press of the power button, that there is no functionality when that cable is unplugged. Obvious in hindsight. I'm going to plug everything back in and try to take the measurements from the back of the power supply board, but I thought I'd note that I only got voltage on 1 pin using this first method. Pin 3 on CN801 had 5.08vdc (labeled "stb5.3v"). Everything else was 0. I also wanted to double check to be sure that taking the measurements from the board with both cables plugged in was in fact the correct approach. I'll post the aforementioned numbers when I can get back to working on it after lunch. Also, this time after leaving it plugged in for a while, the sound was like a rapid beeping with slight static. I'll try to time it next time and possibly video the next noise if it will be of any use.
(This post was edited by bcarroll_us on Jul 24, 2016, 5:22 PM)
