Silentblades
Aug 3, 2012, 7:01 PM
(1086 views)
Samsung LCD help!
So my tv Samsung LN46B630 has been down for over a month tech has been out here twice but I am convinced he is terrible at his job. Anyways this is what is happening. If the tv is left unplugged for 15 or so minutes it will turn on. If you leave it plugged in (off or on) it will then not turn on again unless it is unplugged from the outlet for a bit of time. So far the main board and the power supply has been replaced. This started happening after the tech replaced the original main board or the board that has my HDMI inputs on it (they were going out). I can only assume that this is the main board because thats what the tech kept calling it. Anyone else here have any clue what could be causing my problems? The tv is under extended warranty but my TECH service is downright dreadful. Thanks in advance
