Samsung Tv Problem
DJ106
Nov 15, 2008, 10:55 PM
Post #1 of 7 (5225 views)
Samsung Tv Problem Can't Post
When I switch on the TV (29 inch Samsung) it keeps switching on and off on its own for about five times. Then it stays switched on . If I switch off the TV and switch it on again within a short period the problem does not happen but if the TV has been switched off for some time even in standby mode, then it happens.
TV Model is Samsung CW 29M206
Thanks
Regards
Nov 18, 2008, 10:16 AM
Post #2 of 7 (5190 views)
Re: [DJ106] Samsung Tv Problem [In reply to] Can't Post
Chances ar its a faulty tube, its junk.
dakota
Nov 19, 2008, 7:31 PM
Post #3 of 7 (5168 views)
It sounds like a cap has lost it's ability to work correctly. It's not the tube and it's not junk.
fixyourowntv.com
Nov 20, 2008, 11:51 AM
Post #4 of 7 (5159 views)
Re: [rrobor] Samsung Tv Problem [In reply to] Can't Post
The reason I say its likely to be the tube is because its going on and off. If its a dried out capacitor sure it may not start due to issues in the supply, but keep working it and it will blow the horizontal or the supply, seldom does a repairer see a set with a dried out cap and no other fault. If the tube does not balance the processor will adjust the settings to get balance and will switch video and sound off and on.
ngwa70
Dec 21, 2008, 9:49 AM
Post #5 of 7 (4992 views)
I susspect a bad electrolytic capacitor around the power supply.
Paulpablo
Dec 21, 2008, 11:27 PM
Post #6 of 7 (4977 views)
Rrobor is correct! It is landfill time!
IIIUUU
Dec 25, 2008, 7:54 AM
Post #7 of 7 (4941 views)
Brass air fittings [In reply to] Can't Post
Now that is a lot of brass air fittings http://www.liangdianup.com/...ges/airfitting_1.htm there is just about every type
of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
used some of the parts to make my babington wvo bu
