Mar 10, 2007, 7:35 AM
Post #2 of 5
(1077 views)
Re: [AlanThomson] Sharp SX66NF8 problem
Looks odd but should be an easy fault to fix. The Chassis for this is GA-1 it uses IC850 (TDA6109JF) on CRT panel, that for some reason is wrong. Chances are that is all. It does have feed resistor R609 (5.6 ohms safety) feeding 200V, that can be an issue but I think you will find all your issues are on the tube base. I think its worth replacing the IC, cost is under $10
