Sharp lc-60le640u
rvicomputers
Aug 27, 2014, 3:19 AM
Post #1 of 5 (4283 views)
Sharp lc-60le640u Can't Post
New to tv repair, I got this tv with no power. I replaced the power board and nothing happened. Went home ate dinner. hour later came back. It turned on!!! Yea
But... its now not bright in the left corner. Any ideas? did I replace something wrong?
thanks
rvicomputers
Aug 27, 2014, 9:52 PM
Post #2 of 5 (4265 views)
Re: [rvicomputers] Sharp lc-60le640u [In reply to] Can't Post
 Would it help if I put a picture of it??
rvicomputers
Aug 31, 2014, 7:43 PM
Post #3 of 5 (4236 views)
ok I took the picture, how do I put it up? anyone?
Aug 31, 2014, 8:31 PM
Post #4 of 5 (4235 views)
Search for a Ron.M patented® picture posting post.Wink
(This post was edited by jts1957 on Aug 31, 2014, 8:34 PM)
Aug 31, 2014, 11:11 PM
Post #5 of 5 (4229 views)
Re: rvicomputers;...& jts1957 Sharp lc-60le640u [In reply to] Can't Post
rvicomputers;...
Here's the way to do it here;=>..
Here ya go;.....
How do I post pictures?
I'll simplify this.....
1st , take a GOOD pix with your camera....
Upload it (them) to your computer....
Save it as a JPEG......
Save it to your desktop or ???....
Give it a name so you can find it easily....
Go to
http://imageshack.us/ or
http://register.photobucket.com/step1 or flickr or ???
& sign up & join....
They are all FREE to join & use....
I suggest you use imageshack as it is easier....
Upload your pix....
When you upload your pix to imageshack.com use the "Upload Options"
feature....
Click on the drop down arrow where it says "Do not resize".....
Choose 800X600...Skip "Add Label"...(?)....Upload pix...
When posting a pix from imageshack.us do this;...
Select the pix you want to post from "My Images"....
Right click on the image you want to post....
A box with several choices will appear....
Choose "View Image"....
When that window opens , go to the right side where it says;..>
"links to share this image"...
Click on that & click again on "Direct Link" & copy it , paste it
in a new tab to open a new window..
When that page loads up , put your mouse over any part of the pix &
right click to click on "copy"...
Do NOT enlarge the pix...
Come back to the box you are posting in , right click "paste" &
Ta-Da , your pix should pop up full sized & clear as it was taken...
Before you post the pix in the thread , go to the "Preview Post"
button at the bottom center where you are making your post & click
on that one time....
Wait for it to load the post...
Scroll up & check your post & pix...
If the pix is too small or too big , go back to imageshack
(or photobucket) & make the needed adjustments....
PLEASE DON"T post pix we need an IMAX monitor to view....
If you need any further help or info , just post....
The above method is for "Advanced Editor"ONLY !!!
You can NOT paste in the "Basic Editor" mode...
EDIT:...(Jan,31,2015)...
The "step-by-step" can be daunting to read , but , when you do them once or twice , they become simple to do...
For Photobucket;..
After you login & have uploaded you pix , find the pix you want to post...
Put your mouse curser on the pix (It will change to a "hand")...
Right click & then select copy , copy . come back to forum & paste pix...
As I did below...
Good Luck...
Later...Ron.M...Cool...
(This post was edited by Ron.M on Apr 8, 2015, 5:25 PM)
