Sony Bravia KDL-46W5100
CraigH
Jul 13, 2015, 5:18 PM
Post #1 of 24 (4059 views)
Sony Bravia KDL-46W5100 Can't Post
Hello, I have a Sony Bravia KDL series 46in TV. It powers on, the backlight shows activity, then powers itself back off then back on. What could the issue be? If you tell me a board please be specific in which board would cause this and why. Thank you <br>
(This post was edited by CraigH on Jul 13, 2015, 8:35 PM)
Jul 13, 2015, 7:19 PM
Post #2 of 24 (4047 views)
Re: [CraigH] Sony Bravia KDL question [In reply to] Can't Post
Why do people continue to believe there is something wrong with providing a full model number?
We only use it to research your financial and personal history ... jk Wink
(This post was edited by jts1957 on Jul 13, 2015, 7:53 PM)
CraigH
Jul 13, 2015, 7:24 PM
Post #3 of 24 (4039 views)
Re: [jts1957] Sony Bravia KDL question [In reply to] Can't Post
Sorry the only model number I see is TC8503C Im still trying to figure out what KDL model it is besides a 46inch.
Jul 13, 2015, 7:51 PM
Post #4 of 24 (4034 views)
Comcast Technicolor Modem?
http://esupport.sony.com/...fo.pl?info_id=264#tv
"Televisions: The model number is usually found on the back of the television, but sometimes on the front lower portion of the frame. If the television is very large, or mounted on a wall, you may want to check the cover of the manual for the model number, if not, get some help and don't try to move it alone. In this case, you can also probably check your purchase receipt for the model number. (e.g., KDL-65HX729)."
(This post was edited by jts1957 on Jul 13, 2015, 7:52 PM)
CraigH
Jul 13, 2015, 8:23 PM
Post #5 of 24 (4030 views)
Post deleted by CraigH [In reply to]
CraigH
Post #6 of 24 (4028 views)
went and looked again and took the back off. I finally saw the other sticker that somehow I had missed this entire time. The correct model is KDL-46W5100
Jul 13, 2015, 9:40 PM
Post #7 of 24 (4020 views)
What do YOU mean by backlight shows activity?
When YOU mention power on then off/on are you saying the whole TV or the backlight?
How is audio?
(This post was edited by jts1957 on Jul 13, 2015, 9:40 PM)
CraigH
Jul 13, 2015, 10:01 PM
Post #8 of 24 (4015 views)
I have the back of it off so I can see the lights through the little holes. I see the front of the screen turn on as you can see activity. Overall the front goes from a black to being powered on and sort of a lighter black or a dark blue. Cant hear audio
Jul 13, 2015, 10:34 PM
Post #9 of 24 (4009 views)
If "lights through the little holes" are on all the time, it won't be a inverter problem. Obtaining SM.
Any Power/Standby LED blinking?
(This post was edited by jts1957 on Jul 14, 2015, 12:33 AM)
CraigH
Jul 13, 2015, 10:56 PM
Post #10 of 24 (4003 views)
any chance to email me the SM so I can take a look as well?
Jul 13, 2015, 11:08 PM
Post #11 of 24 (4002 views)
Video Failure
1) No Video or distorted video? I presume NONE.
2) Backlights turning on? I'll presume staying on Yes.
3) OSD graphics present? I'll presume No.
4) Heartbeat LED on BU board flashing? This I can't see.
If I have any of first 3 wrong - tell me.
You will need to answer #4.
CraigH
Jul 13, 2015, 11:20 PM
Post #12 of 24 (3999 views)
1. No video
2.Backlights turning on yes but it powers itself off then on again in a cycle.
3.what is an OSD graphics?
4. where would I look to see a blue heartbeat light?
Jul 13, 2015, 11:28 PM
Post #13 of 24 (3997 views)
1. No video
2.Backlights turning on yes but it powers itself off then on again in a cycle. Does the Power/Standby LED cycle on-off in synchronization with the backlights?
3.what is an OSD graphics? Volume bar, Input display or Menu screen, etc.
4. where would I look to see a blue heartbeat light? On the board with the "BU" on it.
Manuals at http://elektrotanya.com/
CraigH
Jul 13, 2015, 11:42 PM
Post #14 of 24 (3995 views)
Thank you I will look at it. Do you have any thoughts on what might be happening though?
Jul 13, 2015, 11:53 PM
Post #15 of 24 (3994 views)
I can't make an informed diagnosis without proper troubleshooting.
I ask a question - you provide an answer. If you don't understand, just say so.
Asking for a 2nd time: Any Power/Standby LED blinking?
(This post was edited by jts1957 on Jul 14, 2015, 12:35 AM)
CraigH
Jul 14, 2015, 1:42 AM
Post #16 of 24 (3985 views)
yes, the Sony emblem lights up on the front and the green power light is on solid. Stays like that for about 15 seconds or so then powers off and starts again after about 5-10 seconds.
CraigH
Jul 14, 2015, 8:31 PM
Post #17 of 24 (3964 views)
Just checking back in to see if the answer I could give was helpful?
Jul 14, 2015, 10:06 PM
Post #18 of 24 (3957 views)
Video Failure
These 4 questions are from a 'No Video' flowchart in a manual at the site I gave you. Do you agree to these answers for this chart and can YOU provide the answer to question 4?
CraigH
Jul 15, 2015, 12:00 AM
Post #19 of 24 (3954 views)
I looked at the BU board but didnt see any flashing lights on it when the plug was in and I could hear the click for power on. The rest of the questions seem correct.
Jul 15, 2015, 12:45 AM
Post #20 of 24 (3952 views)
No Video
If a total loss of video occurs (including OSD graphics) the most likely course of action is to bring a replacement BU board to the service location since the unit is serviced at board-level only. It is unlikely that a loss of voltage from the power supply is the cause since these voltages are monitored and the unit will likely experience a protection shutdown event rather than a no video condition. Although a failure of the backlights to turn on would certainly cause a no video condition, this too would cause the unit to shut down and indicate a failure via the self diagnostics feature. If the replacement BU board does not resolve the issue, the LCD panel is the only other likely culprit.
The presence of OSD graphics with a no video condition certainly eliminates the LCD panel as the cause and the BU board will almost certainly fix the problem.
The BU board contains a flashing heartbeat LED visible in the upper right corner. Always observe this green LED to make sure it is flashing. If it is steadily lit, IC7000 has failed and is the certain cause of the no-picture condition. In virtually all cases of a failure of IC7000 the LED will not flash. Some replacement BU boards may not have this LED installed. Rarely does a failure on this board cause an existing LED to not light at all.
CraigH
Jul 15, 2015, 4:30 PM
Post #21 of 24 (3945 views)
thank you very much. I will look at getting 1 of these boards and replacing it. I appreciate your help and will report back what happens. Thanks again!!
Jul 15, 2015, 5:21 PM
Post #22 of 24 (3943 views)
That's just what the training manual for that chassis had to say, But I had to drag out some responses from you first.
CraigH
Jul 24, 2015, 4:11 AM
Post #23 of 24 (3887 views)
worked outstanding. Thank you for the help!
Jul 24, 2015, 6:23 AM
Post #24 of 24 (3886 views)
BU board? Power Supply board? or Panel?
