Sony KDS-50A2000
spellcraft85
May 16, 2010, 11:40 PM
Post #1 of 8 (1529 views)
Sony KDS-50A2000 Can't Post
OK. I've had the tv a year and a half now and the last few days its had a few issues. Whats going on is that the set will power on with the lamp burning like normal. A moment later the picture will go off screen. Audio works like normal. If you leave it like this it repeats the cycle. While its off, the power light will blink about 25 times. I've done power resets but it was only a temporary fix and then it didn't work after the one time it did. I have noticed an orange light blinking in the rear chassis. Sony has told me there may be an internal problem. Does anyone have any ideas so that I can try to get this working myself as the nearest sony tech is 70 miles away.
May 17, 2010, 12:23 AM
Post #2 of 8 (1524 views)
Re: [spellcraft85] Sony KDS-50A2000 [In reply to] Can't Post
Lamps don't last forever. When was last time (if at all) the lamp was replaced?Wink
spellcraft85
May 17, 2010, 12:26 AM
Post #3 of 8 (1522 views)
Re: [jts1957] Sony KDS-50A2000 [In reply to] Can't Post
None since I have had it. I got it in December 2008 so its about a year and a half old. Plus its the power light flashing and not the lamp which is what leads me to believe its something different. <br>
(This post was edited by spellcraft85 on May 17, 2010, 12:42 AM)
May 17, 2010, 12:55 AM
Post #4 of 8 (1518 views)
On page 51 of the operating instructions; Do any of the four conditions "To maintain the quality..." apply to your situation?
spellcraft85
May 17, 2010, 3:44 AM
Post #5 of 8 (1512 views)
None of those four situations apply to this situation
May 17, 2010, 4:14 AM
Post #6 of 8 (1510 views)
Blocked vents and fans that aren't running are only other things I've had with that set (overheating).
spellcraft85
May 18, 2010, 7:55 PM
Post #7 of 8 (1493 views)
I have it about 2 feet away from the wall on each end at least and its not enclosed. Do you think using some spray air to try to clear the chassis some could clear up any further fan issues?
May 18, 2010, 11:58 PM
Post #8 of 8 (1489 views)
Possibly. Things usually run better/cooler if clean.
