Sony TV kv-27fs120
coax
May 22, 2012, 8:01 PM
Post #1 of 14 (2985 views)
Sony TV kv-27fs120 Can't Post
Hi All,
I have a Sony kv-27fs120 television whenever I press the power botton it blinks four times and stays off.
It seems like these blinks relate to a code, can someone assist me with this one.
Thanks in advance
Regards
Coax
May 22, 2012, 8:15 PM
Post #2 of 14 (2980 views)
Re: [coax] Sony TV kv-27fs120 [In reply to] Can't Post
4 blinks is a diagnostic code as follows:
13 volts not supplied (A board)
IC545 faulty (A board)
coax
May 22, 2012, 11:11 PM
Post #3 of 14 (2974 views)
Re: [mel] Sony TV kv-27fs120 [In reply to] Can't Post
Mel thanks for your reply, Question how can get copy of the said tv diagram?
May 23, 2012, 1:05 AM
Post #4 of 14 (2970 views)
elektrotanya.com
coax
May 25, 2012, 3:01 PM
Post #5 of 14 (2943 views)
Mel, this tv was being used on 110v the user turn it off and back on as a result it refuse to power up.
On the other hand the web mention is not in english.
May 25, 2012, 6:33 PM
Post #6 of 14 (2935 views)
Where it says "appliance", type in your model number, click on search and it will give you a list of SMs to select from. Click on the one you want and when the next page is displayed, scroll to the bottom of the page and wait until the message "download document" appears. Click on this message and walla, you should start loading. Depending on your internet service, it may take a while to download.
May 25, 2012, 6:39 PM
Post #7 of 14 (2935 views)
coax;...
Try;=>.....
http://elektrotanya.com/...egoria=&kat2=all
There's 4 manuals there to pick from....
I suggest;=>..
http://elektrotanya.com/...-6.pdf/download.html
11MBs...
OR:=>...
Also 11MBs...
Scroll down to where you see "Get Manual" on the right side near the cover page of the manual...
Click on "Get Manual" to start the download...
It may take a few seconds for that to load up...
Those manuals should be in English....
IF not post back & I'll see if I can get you English manuals...
Good Luck.....Sly....
Later...Ron.M....Cool....
May 25, 2012, 6:53 PM
Post #8 of 14 (2929 views)
mel;.....
I didn't mean to step on your reply , but as you can see , I was doing the work you see in my post...
BTW;...
Some helpful hints here;....
You can copy & paste the brand name & model number in the box that says:""Appliance"..
ERROR !!!!...
There is NO "download document" on the page !!!!
You are thinking of "Download Now" , which is for a PDF reader....
This is what you need to do;=>....
Have a GREAT day & weekend....Sly....
coax
May 27, 2012, 1:13 AM
Post #9 of 14 (2909 views)
Mel I got the diagram, thanks to you and Ron M. I going to make some voltage checks, I will give you all a feed back.
(This post was edited by coax on May 27, 2012, 1:18 AM)
stephenjamson
Jun 1, 2012, 3:59 PM
Post #10 of 14 (2854 views)
Well all of the above are really helpful things to do, thanks for giving the helpful advices
[link=http://www.air-conditioningflorida.com/ac-repair-hollywood]AC Repair Hollywood[/link] | [link=http://www.air-conditioningflorida.com/ac-repair-miramar]AC Repair Miramar[/link]
Jun 1, 2012, 6:48 PM
Post #11 of 14 (2844 views)
Re: [Ron.M] Sony TV kv-27fs120 [In reply to] Can't Post
Ron
I'm easy Unimpressed They done went and changed the web site so neither of our instructions are any good no more.
(This post was edited by mel on Jun 1, 2012, 7:02 PM)
Jun 1, 2012, 7:25 PM
Post #12 of 14 (2838 views)
mel;.....
I can be a hard nose !!!!
I've been using that website for what seems like years now & the only changes that appeared recently is the way you enter the brand & model number to the "Appliance" box....
ALL the rest is the same....
My instructions in posts #7 & #8 ARE accurate...
Must have been quite awhile since you last downloaded a manual from there....Unimpressed....
Jun 1, 2012, 8:42 PM
Post #13 of 14 (2834 views)
Get Manual will now appear below the download preview pane (at least for us "guests"). Wink
(This post was edited by jts1957 on Jun 1, 2012, 8:44 PM)
Jun 2, 2012, 6:22 PM
Post #14 of 14 (2818 views)
Re: [jts1957] Sony TV kv-27fs120 [In reply to] Can't Post
jts1957;....
That change HAD to have happened within the last wek....
When I was there on 25,May,2012 , the "Get Manual" WAS off to the right side of the cover page....
So , excuuuuse me !!!!
I'm off to find & eat some crow or humble pie.....Wink....
Later.....Ron.M....Cool.....
