Sony Trinitron KV-24FV300
DanO
Feb 1, 2013, 10:39 PM
Post #1 of 4 (1728 views)
Sony Trinitron KV-24FV300 Can't Post
My Sony does not bring up video/audio when I press the power button. The red light blinks at 4 blink intervals. The TV was manufactured in 2002. Can you still get parts? Can someone please advise me. Thanks!
Feb 2, 2013, 12:30 AM
Post #2 of 4 (1722 views)
Re: [DanO] Sony Trinitron KV-24FV300 [In reply to] Can't Post
DanO;.....
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
I don't see any problem getting parts for that problem....
How much electronic/TV repair background experience do you have ????
Later...Ron.M....Cool....
Feb 2, 2013, 3:23 AM
Post #3 of 4 (1717 views)
Re: [Ron.M] Sony Trinitron KV-24FV300 [In reply to] Can't Post
Go to elektrotanya.com and download the service manual. Check IC545 and the resistors and caps associated with it.
Feb 2, 2013, 6:47 PM
Post #4 of 4 (1709 views)
Re: [mel] Sony Trinitron KV-24FV300 [In reply to] Can't Post
mel;.....
With all due respect;.....Angelic...
This is not a forum for Technicians by Technicians...
NOT everyboby that posts here has electronic experience...
Some have a lot of electronic background...
Some have some electronic background...
And a considerable number have NO electronic background...
That said;....
I take issue with you giving this advice all too frequently;=>...
Don't you think it would be a good idea to FIRST see what the OP's electronic experience IS before you arm him/her with a manual that contains the "Factory Menu" codes that I've found out in the past they WILL try to fix ALL their troubles with ????
AND cause more problems that could & did make the set USELESS ????
After it is established that they have some technical knowledge , then it should be decided by the responding tech to give them a service manual or the means to get it , IF they needed it...
That would be you OR me ...
Giving an unexperienced person a service manual or the means to get one is tantamount to giving me a scalpel & doing brain surgery...
Please use some restraint when someone posts & determine IF that person is qualified to get & USE a service manual properly ...
Your call....Smile....
Thank you....Wink...
BTW:...
You & I both know what these are , but , we do not know IF the OP does...
