Wiz
Sep 23, 2005, 10:20 PM
Post #4 of 6
(3397 views)
Re: [Ambienz] Sony Trinitron KV-32S22
Means cheap and easy fix if just solder, if transistors, a few quid. Open up teh TV, and look on the solder side of the circuit board, being careful not to get a shock (many things in the TV store charge). Look at the solder joints, there will be some that look like they have a ring around them. add new solder to these and then check to see if it has worked. It is also quite likely that the Line transistor has gone. if you have access to a multimeter, check to see if pins are shorting (base should short to collector and emmitter one way round, and be open circuit the other way round.) Oliver
