katman
Mar 27, 2006, 11:57 PM
Post #1 of 11
(3876 views)
Sony tv problem
Hi, I have a Sony KV-v26 tv, made10/97 that is completely "dead". I know precisely what kind of surge damage it got - a tree took down a secondary pwr line(breaker off) leaving my house and what it did was sent 115V thru all the neutral/grd in the house when i hit that breaker on, via a short where the line leaves the breaker box i didn't know about. Of all the electronics in my house(including stereo on same circuit as computer)only got my computer's pwr supply(was off), and the above tv(which was on). On the Sony pwr supply board, it did not even blow the fuse but continued on the neutral around to the second vertical black 3 prong resistor with heat sink(location EY30 on top of board - 2s64834). It had partially melted and obviously what i smelled. Thru a knowledgeable friend i was told it very likely this resistor is the problem, and ordered that piece for $19.35. After replacing with the new one, the tv is STILL dead. I have limited electronic knowledge, but it would be nice to find the problem, instead of spending well over $100(i assume) for a new pwr supply. If that's even the only problem. The tv was working flawless. Can someone please offer any ideas on a direction to go in or to try with a multi/voltmeter, like which pins to check at the plug where electricity exits the pwr supply for the next board(to determine if my problem is actually further beyond the pwr supply board and i fixed that?) I sure hope this tv doesn't need to be scrapped, but i know there are good new 27" tv's for under $200. Any suggestions would be GREATLY APPRECIATED, and thanks in advance!
Mark
