T-con part number
Jcpenney
Jan 12, 2017, 3:51 AM
Post #1 of 2 (1034 views)
T-con part number Can't Post
So, i have a 46" rca led tv that around Christmas started having colored vertical lines across the left side of the screen. I did some research and determined it may be caused by the ribbon wires going from the t-con board to the led display, so i took the thing apart and cleaned the connections and put it all back together and the vertical band remained the same. I switched the two ribbons to see if maybe i had a bad ribbon, but the vertical band remained the same on the same side as before. I tried cleaning out the connectors with compressed air with the same result; except now the band is completely black ( picture here: http://i.imgur.com/oupDO2f.jpg).
All this leads me to believe that i need to replace my t-con board. So I'm trying to determine what the part number is, but I can't figure out which of the many numbers is the right one. Can anyone help me? I don't want to buy a part that looks like the correct one and have it not work. Here's the front: http://i.imgur.com/BRJd9VW.jpg. And here's the back: http://i.imgur.com/q17vGfo.jpg.
Thank you!
- Jeff
Jan 12, 2017, 5:23 AM
Post #2 of 2 (1029 views)
Re: [Jcpenney] T-con part number [In reply to] Can't Post
https://www.shopjimmy.com/...427e-t-con-board.htm
Don't overlook the possibility of bad tab(s) on the panel.
