TV Source Problem
ajharvey
Aug 6, 2015, 8:56 PM
Post #1 of 3 (1082 views)
TV Source Problem Can't Post
I've been give an old Philips HD Ready TV from someone at work (I believe a Philips Flat TV 32PF7320), I want to plug in my laptop to play games on. However when I use the HDMI to DVI cable he gave me (that was working fine with a PS3). It won't let me select its input source, however if I use the picture in picture mode on the TV there is my background of my laptop displayed. Anyone have any idea why I can't select an input source when the TV is receiving a signal?
Aug 6, 2015, 9:20 PM
Post #2 of 3 (1081 views)
Re: [ajharvey] TV Source Problem [In reply to] Can't Post
Choosing PC-VGA mode
Press the AV button on the remote
control to display the Source List.
Use the Up/Dn button to select PC-VGA
and then press the > button to switch the
TV to PC-VGA mode.
To return to TV mode, press the AV
button, select TV and confirm with >
button.
Choosing PC-D mode
Use the up/dn button to select PC-D and
then press the > button to switch the TV
to PC-D mode.
button.
Using the PC menus
Press the MENU button to display the
PC Menu.
Use the up/dn/</> button to select,
adjust or activate PC Menu items
namely: Picture, Audio Selection,
Features, Reset to Factory.
Here is a list of different display resolutions available on your TV.
640 x 480, 60 Hz 800 x 600, 56 Hz 1024 x 768, 60 Hz
640 x 480, 67 Hz 800 x 600, 60 Hz 1024 x 768, 70 Hz
640 x 480, 72 Hz 800 x 600, 72 Hz 1024 x 768, 75 Hz
640 x 480, 75 Hz 800 x 600, 75 Hz
(This post was edited by jts1957 on Aug 6, 2015, 9:25 PM)
ajharvey
Aug 8, 2015, 5:12 PM
Post #3 of 3 (1059 views)
Re: [jts1957] TV Source Problem [In reply to] Can't Post
Thanks for your help!
