Dec 22, 2005, 12:09 PM
(1537 views)
Re: [keithcarrier] Teac CT-M685
I assume you have replaced the supply capacitors as those cause the faults. The flyback transformer is not common in that model but leaking capacitors are, so check all the tuning capacitors carefully. These are C410 c412 c430. Check C926 if the plastic has shrunk replace it along with C908 and C910, these two are a must. If D402 was short that will kill the east west and you need to check Q402, Q405 and replace C419 (4.7uF100V) note this can be a tough capacitor, its high current and often standard types dont work or blow up, I tend to use non electrolytics here.
