Toshiba 27a32
reesenurse
Oct 30, 2011, 8:14 PM
Post #1 of 8 (1181 views)
Toshiba 27a32 Can't Post
I changed the batteries in my remote control. Now I have only a distorted black and white picture on channel 3 (channel that TV uses to communicate to cable box). Channel 4 has a blue screen asking to chose language and I cannot get any remotes to allow me to change this screen.
Oct 31, 2011, 2:34 AM
Post #2 of 8 (1173 views)
Re: [reesenurse] Toshiba 27a32 [In reply to] Can't Post
reesenurse;....
Are ANY of the "any remotes" you tried Toshiba remotes ???
Are they generic Universal remotes ???
Do the pushbottons on the bottom front work OK ???
Can you adjust the Vol , chan up , etc with those pushbuttons ???
Did this problem show up immediately AFTER you changed the batterys ???
Are the batterys in correctly ???
Polarity in there right ???
May need this later;...
Do you have a digital camera ????
It IS IMPORTANT that you answer ALL my questions accurately....THANKS...Sly...
Have a GREAT evening.....Sly....
Later...Ron.M....Cool...
reesenurse
Oct 31, 2011, 8:33 AM
Post #3 of 8 (1170 views)
Re: [Ron.M] Toshiba 27a32 [In reply to] Can't Post
Used a Toshiba remote.
Tried a Comcast remote; did not operate the TV only turns it on and off.
Push buttons all work for channels and volume.
Yes problem occurred immediately after changing batteries
Batteries are in correctly
Use to camera question
Oct 31, 2011, 5:42 PM
Post #4 of 8 (1162 views)
reesenurse;...
Since the Comcast remote turned the TV on & off , we can rule out the TV...
The problem seems to be the remote..
The batterys ARE NEW , right ???
How much electronic/TV repair background experience do you have ????
Huh ????
This requires a simple "yes" or "no" answer...
PLEASE answer...
We need the camera now for a SIMPLE test....
What part of that did you not understand ????
Have a GREAT day & week....Sly....
Later...Ron.M....Cool.....
reesenurse
Oct 31, 2011, 6:39 PM
Post #5 of 8 (1159 views)
Yes, new batteries. Yes I have a digital camera. I am a nurse and tinkerer. I have no TV repair experience.
I have the Toshiba remote that came with the TV and the Comcast remote.
Oct 31, 2011, 7:08 PM
Post #6 of 8 (1154 views)
reesenurse;....
OK , that's great....
This test is for the original Toshiba remote....
Turn your camera on....
Point the remote directly at the camera...(About 2' away from the lens)..
While looking at the camera display (You should see the front of the remote on it) , push a button that is for the TV ONLY & you should see a dot flashing in the center of the remote...
Just to verify;...
The Toshiba remote is the one you are having a problem with , right ???
Post results....THANKS....Sly...
Later...Ron.M.....Cool...
(This post was edited by Ron.M on Oct 31, 2011, 7:11 PM)
Nov 2, 2011, 6:48 PM
Post #7 of 8 (1136 views)
reesenurse;....
You OK ???
We lose you for some reason ???
I piss you off somehow ???
I know it shouldn't take 2 days to run a 30 sec test...Unsure...
You find the problem & fix it yourself ???
If so , what was it ???
PLEASE let us know what happened...THANKS...Sly...
Nov 2, 2011, 7:18 PM
Post #8 of 8 (1134 views)
He got called away on a secret mission?Wink
