Toshiba 30HF84
luke9511
May 20, 2014, 11:00 PM
Post #1 of 9 (2001 views)
Toshiba 30HF84 Can't Post
hello everyone my girlfriends parents have this tv and when you first turn it on there is no picture and there is a hissing sound coming from the inside of the tv, if you turn it off and on a few times the picture is awesome and there is no hissing sound.
im thinking the problem is the flyback as i have seen problems kinda like that in arcade monitors and i want to just make sure thats what it is. thanks for all the help and advice!
also here is a recording i made of the noise if anyone wants to hear it and make their own judgement
http://www.mediafire.com/download/3975n6c2op5hld2/tv_noise.zip
May 21, 2014, 12:03 AM
Post #2 of 9 (1997 views)
Re: [luke9511] Toshiba 30HF84 [In reply to] Can't Post
Make sure the anode cap is not damaged and is seated correctly.
Or it could be a bad joint or a capacitor that's arcing.
luke9511
May 30, 2014, 7:28 PM
Post #3 of 9 (1918 views)
Re: [jts1957] Toshiba 30HF84 [In reply to] Can't Post
<span contenteditable="false"><table border=0 cellpadding=0 cellspacing=0 width="100%"><!--reply--><tr><td width="2%"><hr width="100%" noshade size="1" color="#A1A576"></td><td width="10%" align=center><font size=1 face="Verdana,Arial,Helvetica">In&nbsp;Reply&nbsp;To</font></td><td width="87%"><hr width="100%" noshade color="#A1A576" size=1></td></tr></table></span><div style="margin-left: 30px">Make sure the anode cap is not damaged and is seated correctly. <br>Or it could be a bad joint or a capacitor that's arcing.</div><span contenteditable="false"><table border=0 cellpadding=0 cellspacing=0 width="100%"><!--/reply--><tr><td><hr width="100%" noshade size=1 color="#A1A576"></td></tr></table></span>
i desolder some of the caps and tested them with my digital multimeter and they tested fine, i had my fiancee listen and she pointed to where the HOT is or around the power fet, is there a way i can test this fet to make sure its still good and is it possible for it to be semi bad to where its working enough to turn on the tv but working poorly enough to cause issues?
May 30, 2014, 7:37 PM
Post #4 of 9 (1917 views)
Testing caps or other parts randomly usually is slow in identifying the defective one(s)
You DO have an active signal / source connected so that you can answer the question of whether or not it has any sound (music/voice) from any source?
luke9511
May 30, 2014, 7:38 PM
Post #5 of 9 (1915 views)
yes picture is ok and sounds fine but i dont leave it on for long due to that sound
(This post was edited by luke9511 on May 30, 2014, 7:39 PM)
May 30, 2014, 7:50 PM
Post #6 of 9 (1909 views)
Is the anode cap seated correctly? (Careful you don't get knocked on your a$$ - discharge 1st with set unplugged)
luke9511
May 30, 2014, 7:53 PM
Post #7 of 9 (1907 views)
yes that was one of the first things i checked, like i said there some sort of whine or hissing sound coming from the area where the HOT is but i dont see anything that is damaged
May 30, 2014, 8:18 PM
Post #8 of 9 (1905 views)
Try it in the dark and see if you see anything blue/violet around cap or flyback (or anywhere else).
(This post was edited by jts1957 on May 30, 2014, 8:18 PM)
luke9511
May 30, 2014, 8:19 PM
Post #9 of 9 (1902 views)
nope nothing, just that sound is all i hear
