ChrisSussex
Feb 23, 2023, 6:24 PM
(511 views)
Re: [ChrisSussex] Toshiba 32" 32XV555D backlight cutting out
More info: I'd forgotten that I've previously repaired this TV and I've just found my notes. When I bought the TV second hand off ebay seven years ago. it wasn't working. "RECENTLY HAS STARTED TO GET A BLACK SCREEN. SOUND WORKS STILL, AND TO REMEDY ALL YOU HAVE TO DO IS SWITCH OFF AND BACK ON." I bought : TOSHIBA 37XV555D PE0535 V28A000709B1 MAIN BOARD Same symptoms after fitting so I bought: Power Board Toshiba 37" 37RV635D (SRV2169WW) Same symptoms but after discussing on a forum and doing tests concluded the first PE0535 MAIN BOARD was faulty so I bought another: PE0535 TOSHIBA 32XV555D 32XV553D MAIN BOARD and it has been working for seven years. I now realise it probably doesn't use LED as its about 12 years old. So I deduce the PE0535 TOSHIBA MAIN BOARD is probably the problem. Does this make sense?
