Toshiba 36ZP18Q
jamestv
Sep 24, 2007, 2:51 PM
Post #1 of 9 (1708 views)
Toshiba 36ZP18Q Can't Post
TV goes into standby randomly, especially when switched on from cold, worse while receiving terrestrial channels via tuner. There are no obvious dry joints nor does it affected by application of "Freeze it".
Your advice and pointer will be most appreciated.
A circuit diagram will be most helpful.
Sep 24, 2007, 4:18 PM
Post #2 of 9 (1697 views)
Re: [jamestv] Toshiba 36ZP18Q [In reply to] Can't Post
I had a tosh doing that about a year ago and it turned out to be intermittent crt flashover.try running it with the tube base pulled off.make sure it does not dangle down and touch anything else.
Sep 24, 2007, 11:56 PM
Post #3 of 9 (1695 views)
My brother-in-law had a similar problem a while back. It turned out to be a bad microprocessor.
jamestv
Sep 26, 2007, 9:49 PM
Post #4 of 9 (1679 views)
Re: [techchris] Toshiba 36ZP18Q [In reply to] Can't Post
Being a new user to this site, I am amazed the prompt response, thankyou.
I tried temporarily disconnected the tube base-board without success to isolate the problem.
jamestv
Sep 26, 2007, 9:55 PM
Post #5 of 9 (1678 views)
Re: [mel] Toshiba 36ZP18Q [In reply to] Can't Post
Thanks for your pointer, I certainly will look into this. I presume my problem lies within the low voltage areas, thus a circuit diagram will be of great help.
Sep 27, 2007, 8:31 AM
Post #6 of 9 (1665 views)
intermittent faults are always a nightmare.its often a process of elimination.have you prodded around with an insulated plastic stick to check for bad solder joints or loose connections?also unplug the remote sensor board in case its receiving random signals.does the tv do anything odd before it goes to standby?
Sep 27, 2007, 12:24 PM
Post #7 of 9 (1659 views)
Cutting out when cold suggests to me the supply is running rough, Check all the electrolytics in the supply, one may be hi ESR.
jamestv
Sep 28, 2007, 11:17 AM
Post #8 of 9 (1646 views)
Thanks again for your interesting observation. I even borrowed a broom stick to prod around for the offending culprit(sorry for the joke).The reason why I suspect the fault lies within the signal processing areas; a)- TV goes into standby much sooner via the turner but can run for hours while signal through scart connections. b)- The trouble may be teletext circuit connected, sometimes the picture corrupted by some unintelligible blocks of codes on the screen. c)- The problem may be linked with the loss of remote control as you suggested.
By the way, the remote control boad, is it the one directly behind the TV manual control panel and where the on-off relay is?(Board PB9952)
jamestv
Sep 28, 2007, 11:24 AM
Post #9 of 9 (1644 views)
Re: [rrobor] Toshiba 36ZP18Q [In reply to] Can't Post
That was my initial intuition, thanks, I probably will revisit those potential culprits again.
