Toshiba 42H81
Total
Nov 20, 2011, 4:51 AM
Post #1 of 23 (2673 views)
Toshiba 42H81 Can't Post
Hello : Nice forum here , I have a Toshiba 42H81 that I have changed the 2 convergence chips , I'm pretty sure that the 6 resistors are orange , white , gold , gold 2.7 ohms (see picture / link ) http://www.extremetesting.tv/resistors01.jpg . Is that the correct value ? thanks people <br>
I was looking at the lens , and look dusty - Best way to clean those also ?
(This post was edited by Total on Nov 20, 2011, 5:30 AM)
Nov 20, 2011, 12:34 PM
Post #2 of 23 (2663 views)
Re: [Total] Toshiba 42H81 [In reply to] Can't Post
2.7ohms 5%: Red, violet, gold, gold.
3.9 ohms 5%: Orange, white, gold, gold.
And the ones in the picture:
1.8 ohms 5%: Brown, gray, gold, gold.
Total
Nov 20, 2011, 7:00 PM
Post #3 of 23 (2660 views)
Re: [jts1957] Toshiba 42H81 [In reply to] Can't Post
thanks - I took two new pictures are those the resistors that I need to change for the convergence ? looks like 6 - 1.8 ohm - 2 watt (after your help) .. Any Idea how to clean the lens , thanks for the help .
(This post was edited by Total on Nov 20, 2011, 7:04 PM)
Nov 20, 2011, 7:31 PM
Post #4 of 23 (2652 views)
Windex and soft rag?
Total
Nov 20, 2011, 7:56 PM
Post #5 of 23 (2646 views)
<span contenteditable="false"><table border=0 cellpadding=0 cellspacing=0 width="100%"><!--reply--><tr><td width="2%"><hr width="100%" noshade size="1" color="#A1A576"></td><td width="10%" align=center><font size=1 face="Verdana,Arial,Helvetica">In&nbsp;Reply&nbsp;To</font></td><td width="87%"><hr width="100%" noshade color="#A1A576" size=1></td></tr></table></span><div style="margin-left: 30px">Windex and soft rag?</div><span contenteditable="false"><table border=0 cellpadding=0 cellspacing=0 width="100%"><!--/reply--><tr><td><hr width="100%" noshade size=1 color="#A1A576"></td></tr></table></span>
thanks , will clean the lenses , and those are the correct resistors to change ?
74f100
Nov 20, 2011, 7:58 PM
Post #6 of 23 (2645 views)
One additional note on that TV.
There are 2 small jumpers in the corner of the convergence pcb. If you have the chassis in service position, they will be in the upper left corner of the pcb. They supply the drive voltage for the convergence amps. Check them very closely for cold solder, they will break out of circuit and then blow a 2 amp and a 5 amp pico fuse.
Just something to check while working on it.
Jim
HDMI not working
Total
Nov 20, 2011, 8:12 PM
Post #7 of 23 (2641 views)
Re: [74f100] Toshiba 42H81 [In reply to] Can't Post
checked and resoldered the 2 jumpers - they looked good . The problem with the tv right now is that the screen looks warped in the middle section . If I do the one touch focus - no errors at all .. Is there a way to reset the tv back to the factory settings ? Thanks for the help - appreciated .. <br>
(This post was edited by Total on Nov 20, 2011, 8:13 PM)
Total
Nov 20, 2011, 10:38 PM
Post #8 of 23 (2634 views)
the screen looks warped in the center . Any ideas how to adjust this ?
74f100
Nov 21, 2011, 4:19 AM
Post #9 of 23 (2623 views)
Look around for a service manual for the TV. The procedure should be there to explain how to do it, and how to save the settings.
Jim
HDMI not working
Total
Nov 21, 2011, 4:35 AM
Post #10 of 23 (2622 views)
I downloaded the service manual , the only thing that I can find is :
In the manual -  INITIALIZATION OF MEMORY DATA OF QA02
After replacing QA02, the following initialization is required.
1. Enter the service mode, then select any register item.
2. Press and hold the RECALL button on the Remote, then press the CHANNEL s button on the TV. The initialization of QA02
has been complated.
3. Check the picture carefully. If necessary, adjust any adjustment item above.
Perform “Programming Channel Memory” on the owner's manual.
CAUTION: Never attempt to initialize the data unless QA02 has been replaced.
74f100
Nov 21, 2011, 5:11 AM
Post #11 of 23 (2620 views)
Look for a geometry adjustment procedure. That will set green correctly, thus aligning blue and red.
I'll see if I can find anything on it tomorrow.
HDMI not working
Total
Nov 21, 2011, 5:17 AM
Post #12 of 23 (2618 views)
thanks - much appreciated .Will check tomorrow evening . Total
74f100
Nov 22, 2011, 4:33 AM
Post #13 of 23 (2602 views)
I looked through my service center literature. They dropped your model from the information.
That really sucks, I still work on them quite a bit.
HDMI not working
Nov 22, 2011, 8:49 PM
Post #14 of 23 (2596 views)
74f100;....
I ran into that model before & had a problem trying to get the manual.....
I did find a manual for a "50H81" that should be of help with his problem...
I presume the convergence adjustments would be the same even tho there is a difference in the screen sizes...
You're welcome to give it a try....
http://servicetron.com/toshiba-2.html
Scroll down the page till you see 50H81 & click on it...
Your download will start....
It's a 16 MB file...
GOOD LUCK....Sly....
Have a GREAT day & week....Sly....
Later....Ron.M....Cool...
74f100
Nov 22, 2011, 11:33 PM
Post #15 of 23 (2591 views)
Re: [Ron.M] Toshiba 42H81 [In reply to] Can't Post
Thanks Ron!!!!
That is an awesome TV, and I would hate to have to give up on one. I also believe the H82 series are the same.
HDMI not working
Total
Nov 24, 2011, 1:13 AM
Post #16 of 23 (2580 views)
I can't find any menu that will adjust the warpage :(
74f100
Nov 24, 2011, 3:18 AM
Post #17 of 23 (2576 views)
It will be either under a geometry setting or green convergence.
When I have a chance to really look over a manual, I'll let you know. The holidays are a very busy time for us, sorry.
HDMI not working
Total
Nov 25, 2011, 2:54 AM
Post #18 of 23 (2567 views)
appreciated :) Will wait ..
74f100
Nov 30, 2011, 2:30 AM
Post #19 of 23 (2537 views)
I wasn't able to come up with anything at work on this.
Look at the manual Ron provided. Page 13 has the full convergence alignment. Align Green.
Touch focus "should" bring blue and red to green.
If not, complete that full procedure for a 3 colors.
Pay VERY careful attention to the save procedures, it is very easy to erase the convergence eprom. So follow the procedure EXACTLY....And don't ask why I know this....LOL
Jim
HDMI not working
Total
Dec 3, 2011, 5:17 PM
Post #20 of 23 (2513 views)
thanks - will try this ..
Total
Dec 4, 2011, 3:37 AM
Post #21 of 23 (2503 views)
Thanks - I got the convergence issue fixed - Another weirdness - when I first turn on the tv , the screen is all distorted , for around 5 minutes then it looks 100 % . this happens every time I turn on the tv . Bad cap maybe ? ideas where to check ?
ZIANA123
Dec 9, 2011, 5:02 AM
Post #22 of 23 (2481 views)
THANKS FOR THE POST
____________________
http://www.2004fordf150.net
[url="http://www.2004fordf150.net"]2004 ford f150
Total
Dec 9, 2011, 5:04 AM
Post #23 of 23 (2479 views)
Re: [ZIANA123] Toshiba 42H81 [In reply to] Can't Post
