Bazla82
Nov 28, 2015, 11:50 AM
Post #1 of 10
(4643 views)
Toshiba 47WL968
Hello firstly to everyone. I have a Toshiba 47WL986 tv which has died on me, the circumstances it died was there was an electrical fault/surge in my flat and the tv switched off and then repeated to try and restart itself, before I could unplug it.. and now it won't switch on or even sit in standby, no red light or lights at all. Now since then I purchased a new psu for the tv and swapped it out but still nothing when I give her power. Whilst talking to a friend I mentioned that when I test the secondary outputs for 5v 12v and 24v I fail to read any voltage. Now I'm not sure if I'm missing something here but I think I should have voltages at the secondary outputs but my friend suggests that it is likely that I won't have voltage at the secondary outputs until the tv is told to output voltages/switched on. As in another component controls the secondary outputs and is not doing it's job. I hope that what I've posted has made sense and that one of you ... Maybe more are able to assist me with this fault and repair. Really Appreciate it , Brian
