Oct 22, 2007, 7:26 PM
Post #5 of 5
(1279 views)
Re: [landon1937] Toshiba CF1922J
If the vert IC is a TA8403, make sure that you have around 26 volts on pin 6. If not, you have probably blown the fuse/fusible resistor in the secondary 26 volt power supply. (I believe that it is a fuse but don't have a schematic for that specific model). If the voltage is there, it is probably the IC gone bad.
(This post was edited by mel on Oct 22, 2007, 7:28 PM)
