Toshiba
rob123m
Jun 6, 2005, 3:10 AM
Post #1 of 2 (1891 views)
Toshiba Can't Post
Hello HECT7369
You are correct,I took it apart again and rechecked the transformer,What I
was going by was the markings on the back of the board,and when I took a close look at
the top of the board,I saw where the windings went in were not in the same place as the markings
on the back.I will have to look closer next time.Anyway what is going on is,White line going across
the width of the screen when turned on,with the top half showing little white lines all over and
below the solid white line I have nothing but black.I suspected the problem is in the vertical area,
and found one small cap gone,replaced the vertical ic an5521.I have checked some resistors,but
seem to be okay.I am going to have to get a manual for it,unless you have one or any other
suggestions.If possible can you respond to rob123m@yahoo.ca. Thanks Rob
shadetree
Jun 6, 2005, 4:05 PM
Post #2 of 2 (1879 views)
Re: [rob123m] Toshiba [In reply to] Can't Post
c301-c305
