Toshiba Regza 42HL167
strohad
Mar 14, 2013, 1:43 AM
Post #1 of 11 (7350 views)
Toshiba Regza 42HL167 Can't Post
I got this TV from a customer who was gonna throw it out. When you plug it in, all I get is 3 yellow blinking lights then a pause and repeat. I've been reading online in alot of places that this could just need a firmware upgrade, so I tried that according to the steps that I read online, but no success. I also read that the other cause would be the seine board, which is the board with the HDMI ports on it. So I purchased a board on ebay and tried that, but I'm still getting the yellow flashing lights, no pic, no sound, nothing but the yellow flashing lights. Does anyone have any suggestions I can try?
board repairs
Mar 18, 2013, 8:20 PM
Post #2 of 11 (7303 views)
Re: [strohad] Toshiba Regza 42HL167 [In reply to] Can't Post
Just had the Toshiba 42HL196 in with the 3 blinks & it was the power supply . I replaced the IC on the top right . It was a STRW6765 mounted on the metal heat sink . Did not write down the IC location # of the board . The IC had 6 legs on it . Hope this helps but most of all can you solder ? And be careful as the power supply still holds a charge & when soldering or removing parts shorts can happen . If you can't do the job & you have this part # on your power board take it to a shop & have them swap it out for you or you can try to find a new board & swap it out .
Good luck
strohad
Mar 18, 2013, 8:44 PM
Post #3 of 11 (7298 views)
Re: [board repairs] Toshiba Regza 42HL167 [In reply to] Can't Post
Ty for the info, and yes I do know how to solder. Is there any way to discharge this stored power before i start messing with things? Or just be real careful what i touch?
board repairs
Mar 18, 2013, 8:56 PM
Post #4 of 11 (7299 views)
Just be careful . Not sure if your board has this part on it since they are different models , but hopefully it will take care of your problem .
I don't have a service manual on it to help with the voltage flow & the customers tv which i fixed was told by Toshiba rep it was the seine board as well . But it wasn't the case .
Hopefully that is your problem as its a cheap fix .
Good luck
strohad
Mar 27, 2013, 2:22 AM
Post #5 of 11 (7256 views)
Well my TV doesn't have the same IC, it has a STRW6756, but it's in the same situation as the one you said about, screwed to a heat sink and solder'd to the board. I bought one and replace it, but now when i plug the tv in, i don't even get the yellow light flashing. I guess it's possible I bought a bad chip. I don't know where to go from here.
board repairs
Mar 27, 2013, 5:05 PM
Post #6 of 11 (7246 views)
Not sure what to tell you except maybe check your connections . You could have received a bad part too . Check to see if you've blown a fuse . Do you have a volt meter ? Can u check to see if any voltage is present at the IC you replaced . I do not have a service manual for that set . Have you tried putting the old part back in & get the set back to the 3 blinking lights ? If you have a meter i would check voltages first . Set may use pico fuses which could be a green or yellow color . This part can be static sensitive so be careful when you handle it . Let me know if i can help .
strohad
Mar 27, 2013, 6:17 PM
Post #7 of 11 (7243 views)
at this point if it's not the board that I've already replaced, would it be safe to say that it definately has something to do with the power supply, I found a few on eBay and at this point it's probably just better for me to replace the whole power supply then struggle through different components
board repairs
Mar 27, 2013, 8:43 PM
Post #8 of 11 (7237 views)
Nothing is 100% safe in saying the power board is for sure your problem . I would lean that way but without a service manual & voltage testing it would just be a guess . Hate to see u put more money in for nothing . Looking thru my files i have not seen that model # comes thru my doors . Wish i could help you make the call on that one .
strohad
Mar 28, 2013, 2:12 AM
Post #9 of 11 (7232 views)
Well, I bought a power supply board from ebay, only $30. I'll let you know what happens when I get it, should have it by this weekend. Thanks for the help and ideas.
strohad
Apr 1, 2013, 3:59 PM
Post #10 of 11 (7165 views)
Well I got the new power supply and it got me back to the 3 blinking lights again. At a lose now, don't know if it's really worth going any further with it or not.
Apr 1, 2013, 9:29 PM
Post #11 of 11 (7159 views)
Go to elektrotanya.com and download the repair info for that model. There is a flow chart for trouble shooting the three blinks as an error code.Unsure
