Toshiba TV(CF36G55)
TV Repair
Sep 1, 2004, 2:27 PM
Post #1 of 4 (2940 views)
Toshiba TV(CF36G55) Can't Post
This tv was hit by lightning:
Replaced the following which were damaged:
Location no.s taken off board:
Q840
T840
QA02
Q501
Q883
Problem:
When you first plug up set will come on and turn off, red light is flashing. Can short outQ830 set will come on and picture looks okay, color ok, sound okay, tuning okay.
Release the short and tv will go off.
Do have 12 volts on relay.
Voltages I have taken:
Q830: emitter..0 Base...0 Collector...5 volts
Q843: emitter...0 Base...0 Collector...12.5 volts
Qa02: ;pin 5, 6, 8 all have 5 volts
Q840: Pin 1...5 volts Pin 2...5 volts Pin3..0 volts Pin 4...3.9 volts Pin 5...12.5 volts.
Problem cannot turn on with on/off switch:
Appreciate any help:
Rogers Electronics
1225 Birmingham Road
Sulligent, Alabama 35586
1-205-698-8047
shadetree
Sep 1, 2004, 3:28 PM
Post #2 of 4 (2932 views)
Re: [TV Repair] Toshiba TV(CF36G55) [In reply to] Can't Post
microprocessor ic or something around it bad ,I have had open resistor by ic but most times ic was bad too
TV Repair
Sep 2, 2004, 2:53 PM
Post #3 of 4 (2917 views)
Re: [shadetree] Toshiba TV(CF36G55) [In reply to] Can't Post
Do you know where I can get the microprocessor.
Thanks,
Roger
shadetree
Sep 2, 2004, 4:24 PM
Post #4 of 4 (2910 views)
tritronics 1-800-638-3328
