Oct 7, 2004, 9:54 PM
Post #2 of 4
(2321 views)
Re: [Anderskinny] Toshiba Vertical Collapse
Although I do not have a schematic for that specific model. the vertical output components are uisually labeled in the 300 series (e.g. IC301, C301, etc.). This IC is your most likely problem. I believe that there is also a fuse (F301) in this circuit that you should check first. I usually replace all of the electrolytic capacitors in this circuit when doing repairs because they seem to have a very high failure rate. Meanwhile, you might want to chack out www.FreeFlatScreens.com/default.aspx?referer=7509165 for an opportunity to earn a replacement for this set with a little effort on your part.
