didough
Aug 15, 2007, 8:16 PM
Post #11 of 12
(1628 views)
Re: [tate1] Tuning Bush 28WST66
Also did a search on the Ask Me Helpdesk and found this: Your remote should have the number 4400 ? Press and HOLD the menu button for at least 2 seconds. The audio menu will be displayed followed by the overview menu. Select number eleven by keying in the number one key twice - or select a higher number. The channel cursor will move to number eleven from number one. Press and HOLD the WHITE (Index) button for at least 2 seconds. The word BUSY appears below the menu and starts station search. Stations will be stored in received order. BUSY will change to READY. To regroup the stations into your preferred order: Press P+ or P- button to select the station you wish to change into position one. Press GREEN button. The bottom section of the menu turns green to indicate ready to change. Press number one key and after a few seconds the channel cursor will move to position one from its previous position. Press GREEN button again to confirm the change. Select the next programme which you want to change (to position two). Do this by pressing the two relevant numerical buttons such as one followed by four for fourteen. Press GREEN. Press number two key, the channel cursor will move to position two. Press GREEN to confirm the change. Follow the same steps to reposition the remaining programme positions. PLEASE NOTE that when changing the position of programmes (as per above) the changes MUST be completed in order, starting from 1, the 2, 3, 4, etc. Therefore you may either end up with the VCR as channel one, or you may prefer to leave it at the default number that it is automatically allocated to (which would be a double digit such as 10, 11, 12 etc.). Most video recorders have an option to 'send' a tuner signal (often one or two black bars). If yours offers this, I suggest that you use it as it will make recognising the vcr channel easier during setup. Will give it a go and let you know if it works
