UN65NU6070FXZA No Picture
joeltrg
Feb 29, 2020, 11:59 PM
Post #1 of 3 (2035 views)
UN65NU6070FXZA No Picture Can't Post
Good evening everyone,
I am not sure if this is the right forum to post in so if it's not feel free to let me know.
I recently picked up a 65 inch Samsung TV for free from Facebook marketplace. It was free because the owner of the TV said it didn't work. Of course I assumed that I could fix it rather easily and picked up the TV. After bringing it home I plugged it in and realized that it appeared that the backlight turned on but it wouldn't show picture. The only thing that shows up is a faint grey screen and the audio works perfect. I replaced the main board and the power supply board and then today I replaced the ribbon cables. Please let me know what I'm missing I'd love to get this TV working.
Thanks!
Joel
Samsung UN65NU6070FXZA
https://postimg.cc/gallery/1go1fc0ps/
jeffreyulrich
Mar 11, 2020, 7:28 AM
Post #2 of 3 (1955 views)
Re: [joeltrg] UN65NU6070FXZA No Picture [In reply to] Can't Post
Fault 1: there is only sound, but noise and no image after power on, which may be caused by high frequency head and medium emission. Generally, the video tube shall be able to display the setting menu of the machine. If there are audio and video input interfaces, the external audio and video signals can be played. Fault 2: there is normal TV program accompaniment, indicating that the high frequency, intermediate frequency and accompaniment circuits work normally, and the line output circuit has no short circuit fault. If the TV setting menu can be displayed on the screen, the failure may be in the section where the audio is separated from the video. Fault 3: normal sound, no screen menu, no external video signal. Turn up the brightness and contrast (the remote control can't be used normally, if the machine is equipped with adjustment), pay attention to the screen performance, turn off the machine. If you can see that there is a flash of light on the screen at the moment of turning off, and there is a slight discharge sound, the picture tube is generally not a big problem. Fault 4: open the back cover of the TV, power on to check whether the filament of the picture tube is on (the filament is burnt out, which is not common). Check the working voltage of each pin of the picture tube, especially the cathode voltage, which should change with the brightness adjustment. If the brightness adjustment is in the extreme dark, the electron gun of the picture tube hardly emits electrons, and the image is not. Trouble five: most TV sets now have remote control and electric adjustment. If the CPU chip fails, the brightness will be out of control, and there is no image
Mar 12, 2020, 2:57 AM
Post #3 of 3 (1940 views)
Re: [jeffreyulrich] UN65NU6070FXZA No Picture [In reply to] Can't Post
I think you should lay off the marijuana, medicinal or aftermarket. Crazy
(65" ... Don't ask me to help lift that TV. The 32" & 36" CRTs were killers.)
(This post was edited by jts1957 on Mar 12, 2020, 3:01 AM)
