VIZIO E470VL
bruceeeee@
May 15, 2016, 4:18 PM
Post #1 of 5 (1678 views)
VIZIO E470VL Can't Post
I have a VIZIO E470VL. Input display stays on screen?
May 15, 2016, 4:43 PM
Post #2 of 5 (1677 views)
Re: [bruceeeee@] VIZIO E470VL [In reply to] Can't Post
Be sure to match with Main board parameters for your version.
http://www.shopjimmy.com/...oard-eeprom-only.htm
IMPORTANT:
These main boards can have multiple failures, in addition to the EEPROM.
If EEPROM replacement does not repair your board, there are likely additional problems.
Symptoms EEPROM replacement CAN fix:
- Display is frozen on VIZIO logo screen
- TV turns on when first plugged-in, but it won't turn back on after 30 minutes of being off
- TV shuts off and goes back to standby mode (orange VIZIO lit) after you turn it on
Symptoms EEPROM replacement CAN NOT Fix:
- TV turns on but has NO backlight
- TV turns on AND backlights are on, but has no video display at all
- HDMI issues
- Audio issues
bruceeeee@
May 15, 2016, 6:34 PM
Post #3 of 5 (1669 views)
Re: [jts1957] VIZIO E470VL [In reply to] Can't Post
It's not just a button to punch. Sounds above my skill level if it is not that.
May 15, 2016, 9:25 PM
Post #4 of 5 (1659 views)
That may correct the problem of a User NOT knowing how to use their item.
(You shouldn't expect to connect to a website if your wifi was turned off earlier by yourself.)
bruceeeee@
May 15, 2016, 10:28 PM
Post #5 of 5 (1657 views)
I do know how to use it. I moved the TV to connect the ROKU and thought I may have hit a button. But nothing I try to do resets it.
