Feb 11, 2012, 9:35 PM
Post #2 of 4
(2667 views)
Re: [Bizman67] Vizio Buzz Noise
I think that I need more specific info: Is the set working other than the noise? Can you identify the specific component that is making the noise (transformer T???/coil L???/etc.)? If so, it will be a lot cheaper to change the component than the whole board. Also, if a transformer or coil, spraying with clear acrylic spray might solve the problem. Voltage board = power supply board? What part are you planning to order?
