Vizio L30WGU help
skir0987
Jun 14, 2012, 8:34 PM
Post #1 of 4 (1833 views)
Vizio L30WGU help Can't Post
Hi,
I have a Vizio L30WGU TV that is broken. It turns on and flashes the backlight for about a quarter of a second and then stays on but no backlight. I assumed it was an inverter issue, but replacing the inverter board did not help. I also tried replacing the main board and power board, but nothing has worked. The only board left to replace is the LCD controller board, but I think it's very unlikely to be that board because if I shine a light onto the screen I can still navigate menus and such.
Can anyone help me diagnose my problem? The only thing I can think of at this point is that either the new boards somehow got fried by something else or that the backlight itself is dead (but it still does flash).
Thanks,
Shep
Jun 14, 2012, 9:36 PM
Post #2 of 4 (1829 views)
Re: [skir0987] Vizio L30WGU help [In reply to] Can't Post
Substitute the panel (IF you can obtain one).
Bad CCFL probably.
skir0987
Jun 14, 2012, 10:30 PM
Post #3 of 4 (1821 views)
Re: [jts1957] Vizio L30WGU help [In reply to] Can't Post
Alright, thanks for the quick response. I assume this must be the issue too--although there are other funky things going on. I was probing the inverter board with my multimeter and I noticed it's getting 24V in on each rail from the power supply (normal) but nothing is coming out of the transformers. When the display flickers they jump to their normal voltage but then quickly drop back to zero. Does this symptom fit the broken panel diagnostic?
Thanks
Jun 14, 2012, 11:19 PM
Post #4 of 4 (1819 views)
If Inverter board has B-Plus & an "enable" voltage that comes up (and stays up) when the set is turned "on," then it must be one of the following:
Bad solder joint(s) on Inverter board - sometimes will "char" board
Burnt/charred connectors, resistors or capacitors
Drive to transformer is defective - swap Inverter board with a "Known Good" one.
Transformer is defective - compare one to another - primary to primary / secondary to secondary. (Swap board with a "Known Good" one)
one or more CCFL bulbs are defective - They can get "blackened" ends, physically break the wiring or the glass bulb itself - Visual exam - requires disassembly of the panel in most cases.
Remember the inverter is a "balanced" circuit. It monitors the condition of each CCFL bulbs driving circuitry and can shut the whole board down if even only one item is defective.
If you have a scope you can hold probe close to each transformer (one at a time) as you cycle the set on.
(This post was edited by jts1957 on Jun 14, 2012, 11:21 PM)
