thirty3
Mar 14, 2008, 10:36 PM
(1107 views)
akai pdp5016h tiling
i have an akai that starting tiling, vertical lines and dots across screen, had a tv repairman come and look at it and said i had a bad powerboard. installed new powerboard p/n 3501q00152a. same problem. has three panels inside tv for input, only tiles on inputs, start up screen ok. i connected my laptop to tv with vga cable and screen is ok. so i replaced the tuner board dubhe 5120 and signal board dubhe 5203, same problem. would the vga board dubhe 4b02 cuase this problem since these other two boards connect into it even though the vga port works.
