an5539 sub?
potcode
May 9, 2011, 7:20 PM
Post #1 of 5 (2098 views)
an5539 sub? Can't Post
hi
can a an5515 be a sub for an5539?
or will la7840 be better?
http://www.alldatasheet.com/datashee...IS/AN5539.html
http://www.alldatasheet.com/datashee...IC/AN5515.html
http://www.alldatasheet.com/datashee...YO/LA7840.html
thanks
May 10, 2011, 7:59 AM
Post #2 of 5 (2088 views)
Re: [potcode] an5539 sub? [In reply to] Can't Post
http://cgi.ebay.com/...lar-IC-/150534615265 $7.00
http://nte01.nteinc.com/...emiProd.nsf/$$Search See if they all cross to the SAME NTE number.
(This post was edited by jts1957 on May 10, 2011, 8:05 AM)
potcode
May 10, 2011, 1:57 PM
Post #3 of 5 (2083 views)
Re: [jts1957] an5539 sub? [In reply to] Can't Post
I try nte but no luck,base on the date sheet which one you think will be better?
May 10, 2011, 6:16 PM
Post #4 of 5 (2082 views)
IF ALL proposed substitutes cross over to the SAME NTE number you can use any of them. If they don't, NTE must see some reason that you don't see as to why they are NOT interchangeable.
Just because Chevy and Ford both use "starters," that doesn't make them interchangeable.
potcode
May 10, 2011, 10:14 PM
Post #5 of 5 (2078 views)
NTE has no info on an5539
i have used subs for parts that does not have the same NTE.If i was the one installing the ic base on the date sheet i would try both.Am just trying to help a friend so i want to give the one that is more likely to work.Thanks for the links but am from the caribbean an odering is a last resort
